front arm swap
belgian
Riviere-Beaudette, Quebec, Canada
I would like to know if i can use a front arm (the left one ) from a 1998 Srx to install on a 1997 700sx ? I was told that if the letter V is punched right next to the grease Zerk ,it would fit ... is that true? i don't care about the color i just need the arm ! :) Also I do have kyb shocks on my 700sx , is it possible to swap front shocks fron another model , since i cannot find used ones from an Sx .
Regards . you can reply to this adress if you want
pbousez@rocler.qc.ca
Research first
hey belg--not sure: many people will shoot from the hip on this one, but I believe the spindle angle is different. It is only a degree or two (if my memory is correct) you can look at a suspension manual and figure it out(Mine is out in my trailer) I ran iunto this on a snox sled, but I dont remember what sleds we were swaping--it was an issue.
Check before you buy!!
