Hi there
1983 SS440, when reassembling the secondary, do you place the spring in the correct hole and then twist the sheaves (hole 3, 210 degrees in this case) and push the helix down and install the circlip to hold everything? I forgot how this goes as it has been a while since I took mine apart.
that sounds correct to me.
