Shi-ye09
- Nov 25, 2024
I'm new here, I'm ordering 5 inch handlebar riser and getting some throttle and brake cable extensions. But I have no idea what to do about my headlight switch, Killswitch, and heated grips how are they going to reach the higher bars? If anyone can help thank you
Usually can get enough slack but not sure on 5” more then stock.I'm new here, I'm ordering 5 inch handlebar riser and getting some throttle and brake cable extensions. But I have no idea what to do about my headlight switch, Killswitch, and heated grips how are they going to reach the higher bars? If anyone can help thank you
probably going to have to extend the wiring on the sled side unless you have a source for the male and female connectors to make extension harnesses. from the ones i have played with, +3" is about it.
Mad Maxx
- Feb 18, 2005
You would be wise to reinforce the steering post with a 5” riser. It will break at some point if you don’t . The electrics will have room after some rerouting .
mountain performance used to have a reinforcement for these sleds steering column.
