5000-6000 RPM miss/hesitation
James Guillaume
Hello,
I recently picked up a 98' Venture 600 with only 880 original miles. Overall its in good shape. I have always had Apex's and Attaks but I have never owned a non power valve 600 or a Yamaha 2 stroke twin. I have worked on countless engines and cleaned countless carbs filled with junk. I used to do it as a job at an independent shop but this one has me baffled.
The sled started and ideled great when I got it, but had a terrible bog once you got past quarter throttle. I cleaned the carbs and there was not much change. I cleaned them again and found that one of the pilot jets reclogged itself. I put it back together and it seemed much better. I ran it on a stand and it had some hesitation and then came out of it and would rev out no problem multiple times.
Today we got some snow so I took it out. Overall it runs good, it idles great, starts very quick and pulls hard wide open. It just seems to struggle to get going on hills where it can't get too much speed after the secondary engages. You half to give it like half to 2/3's throttle to get moving up hill. The only other symptom when going slow on flat ground between 5500-6000 it just kind of sounds like it is going between one and two cylinders, or sounds and feels like when a Yamaha triple fouls a plug and drops to two. There is a change though when pulling spark plug wires off at idle so both are sparking.
I noticed the belt was sitting low in the secondary so I added some shim to the back plate and it seemed to take off a little better but its just not as peppy down low as I thought it would be. Am I missing something? Is this typical for a non power valve 600? for reference it feels about the same in the mid range as my old Indy 440 liquid but not as smooth, but pulls up top like any 583 or mid size motor.
It is just something we will use to ice fish with and sometimes ride two up on. I know its not new and nor a power house. Should I go back to the carbs? They are the smart carbs and I tested the solenoids with a 12v source and they all click. The oiler looks to be at the correct mark. I also made sure the air screws were at 1 3/4 turns out. There is no difference during the hesitation if I flick the choke on or off. I feel stuck on this one as I am mechanically inclined and usually can find the smoking gun of a problem but this one I cannot put my finger on. Maybe it is just how it is?
Any input would be great.
You've listed off three things.
Carbs/Fuel supply.
Secondary Engaging
Electrical Gremlings.
I would check your stator coils resistances. A high speed miss/bog is usually electrical. Make sure your coils don't have any loose or open wires frayed.
Almost certainly the main nozzles, which I don't think can be found anywhere.
What makes you think its the nozzles?
High speed BOG, not lean is from a bad coil.
High speed miss is from a bad stator.
Because you said it was a midrange running issue.
You should check the rollers and weights in the primary clutch.
If it isn't one of those issues, then I don't know.
check the flywheel for rust as it can cause spark issues.
i would swap out the primary spring for a new one as that one is probably too weak from sitting/age.
have you checked the crank seals with quick start or flammable brake clean? they tend to dry out when they sit.
those carbs can be a curse or a blessing. seen/heard of a few leaning themselves out and popping motor. as soon as guys had carb trouble, if they swapped out to the xtc 600 twin carbs, it would straighten out and run better.
I seem to have figured it out. Ultimately it was just super rich, gas dripping out of the boost bottle and reeds after inspecting them. I set the idle fuel screws at 1 1/4 turns out, cleaned behind the solenoids and took the needle and seats out and cleaned the seat and needle. They were set a little low so I made them level with the carb body. That helped things and gave it better idle and much better top end and let it rev out fully. The midrange would no longer bog but still sounded poor / hesitate.
I dropped the needles down a notch and now things seem proper. Drives great around the yard and and runs smoother. Need more snow to really see how it performs after a while. Plug electrode is now nice and tan.
Was able to take it out on a 40 mile ride today. Great down low and pulls very hard up top. Better but still poor in midrange. Sucked through a lot of gas too. It also started this morning without choke very quickly. I imagine it needs needles and seats. Does anyone think the nozzles and slide needles could be worn with only 880 miles?
Thank you and glad I am close to figuring this one out. The needle adjustment helping makes me believe it is just getting too much fuel up through the nozzle either caused by a bad inlet needle or a worn nozzle.
Upon further digging one of the needle tips is broken off. I must have missed it at first. Needle and seats ordered
Any help would be great. New needle and seats, marine needles are as far down as they will go. Runs okay, still a little burbly in the mid range. Finally have ridden it enough to now notice only getting about 35-40 miles a tank. I did change the belt and adjust the clutch so it would not shift as quickly which has helped mileage a bit and the bog but something is still wrong. Needle and seats are sealing and the pulse line on the fuel pump is dry. Anything? Ready to set this one fire. Revs out to 7800 no problem, idles great and does not load up.
Already told you the problem. You need new needle jets but probably won't be able to find any.
