Shawnyxtc600
- Dec 26, 2021
i have a vk540 primary clutch and i want to put it on my xtc 600...
i read someone where the offset is 15mm on one and 13mm on the other.. what does that even mean?
i would assume the vk540 clutch would just bolt on the 600 just need to change weights and spring?
also i heard the cylinder jugs are different on the 600s from 1990 to 1996 are differnt than 1997 and 1998s?
i want to order 2 new cylinders pistons and rings for the xtc 600.. where can i find a spec sheet for that stuff???
