tiney
- Nov 28, 2024
Seen a good deal on a viper driveshaft with 8 tooth drivers was wondering if it would fit my sx our be able to use the drivers on my sx shaft thanks.
The shaft will fit but you wont be able to use your speedo on your SX anymore as the SX has a mechanical drive to the speedo cable and the Viper use a pickup sensor with a signal gear on the end of the drive shaft.
