Just picked up a 04 yamaha venom. Looking to make my own hyper venom with pipes and 700. Got couple of questions. The venom 600 timing curve work with 700 or can I install a cdi box off a 02 sxr 700 to fix the problem? Next will pipes fit off sxr 700 into venom chassis?
I don't have a definitive answer but the project you are taking on is one I had planned at one time as a piped and ported 700 Venom would be a good sleeper and SRX killer.
I have used a 600CDI on a 600 SX converted to a piped 700 and did not have any issues.
I always felt the SX triple pipes would fit or easily be made to fit in the Venom chassis.
I would use Bender pipes if you can find a set.
Good luck.
Good luck.
there was a member on here that did do a venom 600 up with pipes. i think he just used the sxr pipes on his stock motor.
Thats what I have is benders. I wrecked my 1998 sx 700 2 yrs ago. Was going to take that setup and put into the sx venom chassis. I was looking sled over today was surprised the venom dont have a toque mount. So ill upgrade that as well during the build. Probably be my last sled I'll buy in my life time. Thanks for the input much appreciated.I don't have a definitive answer but the project you are taking on is one I had planned at one time as a piped and ported 700 Venom would be a good sleeper and SRX killer.
Good luck.
supercharged111
Was the Venom a PV engine like the Viper? 00sxrjoe are you swapping in a Viper engine or a redhead?
Venom came with the redhead non power valve engine 600 triple version. Newer look of the SX Viper and reliability and simplicity of the Red Head SX and SXRs.
