theflamanguy
Does anyone know what I can do to the Proaction skid on my MM700 to reduce weight? Which wheels to take out? How does this affect hyfax wear? I also wanna customize the sled a little and I thought going with the billet wheels would look cool? Any thoughts???
Thanks,
TFG
Thanks,
TFG
SRXSRULE
- May 2, 2003
Like This? ...I removed all extra wheels, Just running 8's on the back and 7's on the upper shaft. Hyfax wear is a huge problem if you run trails. If you in powder its not an issue. I do run ice scratchers on the trails. ===SRXSRULE===
theflamanguy
Thanks once again that thing is awesome!!!
grapeape
7's up top? Hmmmm That may fix my problem of the top wheels not spinning off-trail and building up with ice. What do ya think Rules?
SRXSRULE
- May 2, 2003
Grape, they are actually 7.25" and no it dont fix the problem. My upper wheels ICE up bad in good powder and dont spin some times. If I did it over again, I would not but billets on the upper shaft. ===SRXSRULE===
grapeape
Well, at least we are in the same boat then
or
theflamanguy. Look at mountainperformance. I think I saw a shaft that saved 2,5 lbs, h arm that saved 6 and a transfer enhancement kit that saved 5
ak ryda
On my mtn viper I have removed all the bogey wheels just like SRXrule but I put the front wheels back on so I would not have to run scratchers. I also have the mountain performance transfer enhancement kit ($50, lose 5 pounds, makes huuuuuge difference in powder, strongly recommended).
I would say between the two I have lost close to 10 pounds for only $50 and have a much better performing rear skid. Cant go wrong.
