Transuranic
- Mar 12, 2025
Can coils from a 2000 srx 700 be used interchangeably? Not finding a definitive answer.
If the sled had, from new, the two bulb headlight it indicates the updated ignition system. The coils from the two headlight bulb, SRXs, Vipers, and SXRs are interchangeable.
Right. However the 2000 sxr is single headlight.If the sled had, from new, the two bulb headlight it indicates the updated ignition system. The coils from the two headlight bulb, SRXs, Vipers, and SXRs are interchangeable.
