Carb help 02 viper
Yes, same as the main jets and air jets. Turn them in till snug.
Or, are you talking about the air screws on the bottom of the carbs?
The stock jets for your Viper were 156.3 so as stated 160 is too big for a stock exhaust Viper even with a can.
For part throttle cruising safety, most people advised to change the needle position from the stock 3 to 3 1/2.
Position 3 would have the needle clip in the 3rd groove from the top and both plastic washers together below the clip.
Position 3 1/2 would have the needle clip in the 4th groove from the top and the plastic washers split between one washer on top of the clip and one below the clip.
These jetting specs are with the carb vent tubes connected to the airbox which is stock on a Viper.
Yep, I would run the stock main jets, move the clip on the needles to be at 3 1/2, and turn the fuel screws to 1 7/8 turns out.
(They are fuel screws, not air screws like I had said before)
Have you ever seen a viper with the vent lines connected to the air box plus a vent or suction hose connected to the top of the carb? On the the black part of the carb, I looked everywhere and couldn’t find one that did which I thought was weird, and yes it a separate line directly into the air box
There is zero chance it needs a jet change for a silencer.
I think most here would agree.
I think the extra hose you are talking about is a temp or altitude compensator system.
I have no experience with them at all, but sounds like that is what you may have there.
Thank you for the information! I will put it to use, ain’t nothing better than a smooth running viper
On a stock 700 Viper all the bowl lines connect into one T fitting that hooks to the airbox.
My viper has a t fitting that’s connected to the air box, it also has a separate line running into the head of the carb, which I find odd
