Give me one good reason I cannot change this bearing without..
norwegian
Well-known member
norway
Give me one good reason I cannot change the bearing behind the secondary without opening the chaincase?
Seems like I found a problem, the bearing holder seems to be inside of the frame, so I can't push the outer half out of the way
Depending on what sled, that inner portion is riveted on. I have had to remove a few for different situations other than a shortcut. Those rivets are hard, but easily ground down and then punched out, assessible from the clutch side of the bulkhead. If memory serves correctly, no need to re-rivet as the through bolts lines things back up.
