For Turk, advant edge spare parts?
norwegian
Well-known member
norway
Hi
I know you have an advant edge roller on your mountainmax? How is it modified? Anyway, my question is, are there replacement rollers avaiable? Can't see them listed on their site. Thanks
I have since sold the sled but Rick from advant-edge does sell the rollers. I still have the roller on my RX-1. Make sure you lube the roller with WD-40 over summer lay up or they will sometimes seize. After I learned my lesson I had the rollers last 3 seasons & were still working well when I sold the sled.
Will the Advant Edge roller helix/system allow the secondary to fully open so one can reach overdrive? This is the responce I got from Hauck when I asked them about why one has to use a hauck helix with the speed sheave for the primary:
The reason we recommend the Hauck helix is because it is machined so the secondary will open far enough that the primary can reach overdrive. Thanks.
Titus
