culvert
Looking to install a newer set of plastic skis onto a 95Vmax.
what parts do I need to make this possible? Will the saddle from 98+ sleds skis work on the 95?
Thanks, and HAPPY NEW YEAR.
I would think you could retro fit something, but the pogo stick bottom had the alum block that sat into a small rubber stopper in the pre 97 ski....if you can groove out the std rubber block in the 97+ ski and still get the bolt hole to line up....should work. I have a few extra rubber blocks if you need some to carve on.
vmaxjohn
I think all aftermarket ski makers have mount kits for your sled. Depends on what skis you're going with.
Really John, I didnt know that.....LOL. I was tlking about OEM....
Yammerhead
I believe the alum block on the pre 97 sleds is wider than the newer ones. I bought ski's that had saddles for a 96 sled and had to put washers on the through bolt between the saddle and alum block to keep it from moving back and forth laterally. I would assume you would have to cut down the block to make newer saddles fit on the older sleds.
vmaxjohn
Tom, are you joking on me?hehe
If it's Yamaha skis you're trying to retro fit, you might give USI a call, since they built them for Yamaha. I think they take the same mount kit as the USI ski.
