Throttle Slide Height
REVREND
Hey Guys, I am working on my 1999 500 Vmax sx Twin.
I need to know what height to set the Throttle Slide Height at.
This is the first time anyone has ever opened up these carbs. I found that the two carbs aren't synchonized. I could actually see the difference in the two heights. The float heights were way out of wack too.
Cheers!
Drill bit?
I was told to use a drill bit to measure the amount that the slide is open. I am just wondering what size drill bit to use??
the center one is the master, you want the other ones set the same as the center on the triples
