RockSteady
- Dec 15, 2003
I hate to be a pain,but it will snow someday and I have get this sled running (for the kids)
After taking apart my carb (for the 3rd time) and cleaning it. I still have the same problem - engine will not run when choke (starter is off). It will run with choke on BUT at full throttle will run for about 5sec. than bog down. When choke is off it just stalls, when gas is given it also boggs down. Cleaned carb and jets (like I said 3 times). Is there something I can try??I will get a rebuild kit, Will this help?? (Any suggestions where to get one)
The carb lists several different jet sizes (besides STD) WHY?? Which is better? What is the difference??? On Ronnies web site. Does someone a COMPLETE rebuild kit (instead of just OEM replacement pieces)
Thanks for any help
ED
ED
Thanks for any help
ED
ED
Phazer
Try spraying carb cleaner around the crank seals and fuel pump pulser hose. You might have a vacume leak.
RockSteady
- Dec 15, 2003
I will try that !
Ed
Ed
