hlmrx1
- Jan 6, 2005
Anyone have an electrical diagram on this sled or know where I can find one on the internet or something?
S
srx_eh
Guest
Check yamaha.com snowmobile user manual section, you can find a wiring diagram near the back. If your still stuck, I might be able to post a scanned copy from my shop manual.
hlmrx1
- Jan 6, 2005
If you could, I wouldn't mind as you can't print the pdf files from the yamaha site, thanks.
S
srx_eh
Guest
I'll see what I can pull out of my hat tomorrow, ...there is a freeware tool called ghostview/ghostscript which allows you to hack pdf for printing, ...works great (search the web).
hlmrx1
- Jan 6, 2005
Well, found ghostview/ghostscript, installed and tried to open and print, ghostview gets an error and tells me the file is encrypted.
S
srx_eh
Guest
Give me your email address and I'll send you the schematic (too large for this site).
S
srx_eh
Guest
hlmrx1 said:Well, found ghostview/ghostscript, installed and tried to open and print, ghostview gets an error and tells me the file is encrypted.
Worked fine for me, ...copy manual from Yamaha site, ...run ghostview, ...and open pdf, ...should be able to print.
