bender weights
grippper
Lake Elmo MN.
right now i have a bender clutch kit in my sled. i weighed the weights from the bender each one weighs 46 grams.i bought a used thunder shift kit each weight weighs 47.2 grams. what would this amount of weight change.any guesses. the thundershift kit weight has a 3/8 in aluminum in hole 1 3/8 steel bolt steel washer and brass washer in hole 2 and the same for hole three.
Who knows?
It might not mean a damn thing. It all depends on the profile and where the weight is located. I have different set-up's for the same motor with very similar spring combinations that vary by almost 10 grams depending on the weight. All you can do is go with the set-up tha Bender suggests and adjust from there.
Madmatt
