caribfuture
what does a mostly stock '01 SRX 700 sled run RPM wise at WOT? Before I ripped the drive bearing out this weekend, I got a chance to hit WOT for a sec or so and was running around 9k or slightly over that. Just wondering if that sounded normal with what everyone else has experienced. Thanks
S
srx_eh
Guest
I would think 8,400-8,500 would be a good rpm. for that sled stock. Get your bearing sorted out and you might want to add a little weight to your primary to get those rev's down.
unimog
Should be about 8250-8400rpm
yamaholic22
2001SRX=Fast
i am running 8500-8700.
yamaholic22
8500-8700 you are losing a couple of horsepower (provided your tach is accurate), but it may run fine there. They are all a little different
Danger Dog
Most all the SRX tachs are within 50 rpm so I would through alittle weight at her and bring it down a couple hundred.
tonkatoy01
Thats high! put out the box they over rev. you what 8300 to 8400
ask turk he is the clutch man
