Viper Mtn 2.5" Track ?
sixat38
Spokane, WA
In a nut shell, has anyone done it?
I realize at the very least you'd have to put 7T 3" pitch drivers but will the track clear the front heat exchanger?
Doubtfull from looking at it.
If it won't clear, what about removing it and putting a larger rear exchanger in? However, would that generate enough cooling?
Or slightly mill a little off a couple of the fins on the front heat excahnger closest to where the track passes by it?
Anyone? Jim
You can go 2.25 with 8t but 2.0 is the max with a 7t 3.0 pitch (larger dia then 8t 2.5). ===SRXSRULE===
do they make a drop and roll kit for the new style ones now? i know they did like crazy for the older style mountain max's to make them like the new style ones when the 141 first came out, but i dont think i have seen any to roll the new ones ever farther???
