nystateboySRX
what am I looking at for cost on a rebuild from the crank on up:
just the crank needs to be rebuilt or i think im having a recondition one put in.
On that said, everything else in fine and just need to be put back together.
So what am I looking at for cost??
yamaholic22
what all needs to be done to the crank? All new bearings? If you need all of the bearings, that is expensive, probably not even worth rebuilding, as you would be better off to find a good used one. If it just needs one or two bearings and a balance, not near as bad, can get it for probably around $200.
nystateboySRX
its not any of the bearings. its the PTO balancing lobe that cracked.
yamaholic22
the most expensive part will probably be the actual lobe. The labor isn't too bad, especially since its the PTO lobe. Definately going to be at least a couple hundred total though
greg
A company out of Quebec rebuilds cranks and they also do Nika Tech re-plating on cylinders. Good prices, good quality I have been using them for 5 years with no problems. www.atelieradrienbernard.com 418-335-7220 With the exchange rate prices will be even better.
