600sx jeting
sxtuner
man. can.
I have 600 sx tripple bender pippes and a tempa-flow worked great with carbon tech reeds. Then wore out the reeds and changed them with carbon tech reeds (soft) acording to bender racing tip. didn't work right, Idel went up to 3000 to 3500 RPM and when riding the trails at under 6000 RPM it just didn't have the throttle responce I had before (sounded fat to me) but after 6000 RPM I had to hang on. Every thing else is the same as I had it before and it worked fine.Any tips?
check your plugs and piston wash below 6000, and then again above 6000. Maybe there is a lean or rich spot in the circuit. Tempaflow affects the main jets alot more than the pilots and needles as well
checked plugs at both stages dark brown under 6000 light brown over 6000 and the wash is a little on the lean side over 6000 never checked under.
