KillianNJ
Need to know torque specs for putting a SRX back together
Head
Cylinder
Upper and lower block.
Any other?? Let me know ASAP.
Head
Cylinder
really should look in the Tech area for answers http://www.totallyamaha.com/snowmobiles/aaTECH/Simple_Specs.htm
KillianNJ
MrSled said:really should look in the Tech area for answers http://www.totallyamaha.com/snowmobiles/aaTECH/Simple_Specs.htm
I got those two from their but what about the lower half of the motor.
A buddy is replacing the crank on an SRX and wanted to know the lower half and upper half torque setting.
snowprophet1
torque specs
98 srx shop manual specs... crankcase halves-1st to 9.4 ft lbs, then final-19 ft lbs (2.7mkg, 27Nm). magneto-61 ft lbs., head-first 9.4 lbs, then final-20 ft lbs, cylinder base bolts-24 ft lbs.
