viper s sway bar links
blueblooded
Lockport ny
When riding hard threw rough trails my sway bar links spin upside down causing the sled to lean to one side.Its happened to me 3 times twice on the left side and once on the right side.I turned the clickers on the ohlins to a stiffer position,i was 6 out from stiffest now im 3 out from stiffest.Did this ever happen to any of you?
Only time I ever see that happen is after someone just took out a trailing arm. Never seen it happen from normal riding and I use to pound the trails pretty hard. good luck. ===SRXSRULE===
happened too me once,I was comming out of a frove pond up a steep incline and there was a big old stump,and hit it.Just spun it back around and never had a problem again.
