ET410TRW suspension and other mods
low slung
Newfoundland
The biggest inprovement to make the rear skid ride better is to install grease fittings in rear shafts.The bottom front arm and rear top arm is all you need.Skid moves much smoother.Remove all heat shields in cab,cools motor better.PS has anybody out there changed the track on there machine.Can the drive shaft be removed without taking the chain case cover of.It looks like it just slides into a teethed cylinder on the back of the bottom gear of the case.
