99 sx600 trailing arms replaced with ones from a 00 vmax
ekimsx600
guelph ont canada
Website
www.freewebs.com
I have a 99 sx 600 that I bought that needs some front end work. I want to replace the trailing arms and radius rods with the ones from a 00 vmax. The spindle angle is differenton the trailing arms and the radius rods are longer on the 00. The result of putting these parts on the sled is a wider front end. I'm using the KYB shocks that came on the 99 so the angle of the shock is a little more. Does this sound like a problem to anyone? Any insight on this problem would be great.
Your sled will sit very low with those short shocks. Best would be if you get hold of a set from an XTC or an sx-R/Viper.
