Will it fit?
sockeyerun
Test Dummy
Anchorage,AK
Anyone know if a throttle cable off an RX-1 mountain will fit a 700 Mountain Max. Aren't they longer than the MM ? Sure would rather use one of those instead of an extension. Thanks, Soc
I used a 02 mm cable on a Rx, but I had to make a spacer to make the sleeve longer for the Rx. So my guess would be no as far as using it the other way around IMO
