nailsandrails
00 ported SRX. 48-36 helix green spring @ 60 40-10 clickers with 4g heel 4g center and 3g tip. It hits 8500 off the start, but seems to fall to 8400. It also would only run about 90-95 at times. Other times it would do 100. I looked at the clutches and the primary is slipping. Black marks at the top. I was going to change it to 4g tip and 3g center, but never had time this weekend. What do you guys think?
nailsandrails
Just bumpin to the top. I know some guys on here have heelclicker knowledge.
kawirider00
sounds like your revvin good but sometimes porting makes its power at different rpms who did it do they have specs new belt/ adjust tighten the helix to 80
h/c
I personally dont like to run weight in the middle hole, slows the engine revs down, and doesnt have the consistant smooth upshift. I like heel and tip weight, and with your shallow finish you can do it. Try 4 washers,1 lock washer in the heel, then empty middle, and long bolt with 2 washers in the tip, you want to make sure the bolt will clear the spider on the sides, sometimes you have to grind the side of the bolt head just a tad to clear, see how that works. Gonna need you to watch the tach and give some details in order to dial you in from here.
Rollers
This may be obvious but make sure you are using the correct rollers with those weights.
Madmatt
Madmatt
nailsandrails
I am just using the stock rollers. I don't think they need to be changed on this sled.
