power valve
just wondering if I can run 1 1/4 chisels on an srx without ruinning the heat exchanger or tunnel. Do not want to trail ride just want to use them for speed runs at the end of the year.
thanks
thanks
srxxx86
- Dec 31, 2004
yes you can use em considering ppl use 1.375's in there ripsaws
yamaholic22
yea you should be fine as long as your protectors are still in there
kawirider00
its risky but it can be done better off with 1.075 espesially since chisels are used for hole shot mostly lot of torque throwin them forward
SRXSRULE
- May 2, 2003
It depends......what track are you using? If your runnign the stock .92 or a 1" track, yes you can run them, just keep yoru track tight. If your running a .750 or a .540 speed track, your going to tear the shit out of your tunnel. I use to run 1.25" square aluminum tubing for tunnel and heat exchanger protection on my race sled so I coudl run long studs and a speed track. ===SRXSRULE===
