Viper Clutching- Turk- Please Help
MADVIPER
Nisswa Mn.
I Have A Stock Viper. 1.5 Inch 8dl-oo 121" Track. I Looked At Your
Specs In The Tech Section, And Have Done Alot Of Searches But
With No Luck. I Dont Have A 53/43 But I Do Have A 56/44. Any Chance With This? I Also Have A 43/37 And A Nickel Plated Hauch B Helix
And No Idea Of The Angle. Think I Had It On My Srx. Any Chance Of
A Direction? I'm Going Out To Try Some Stuff Today, But Some Advise Would Be Greatly Appreciated. Thank You!
56/44 will work. Kinda steep tho!!!You might have to remove some rivet weight out of the primary. Wrap that puppy pretty tight in the secondary too.
Should I Use A Green Or Red Sec. Spring To Start With? Any Thoughts? WHAT
RPM DO YOU SUGGEST FOR ADJUSTING WEIGHTS?
