MountainMax
RE: another clutching question
Hey guys, i was out running my sled with a slightly warn belt, my revs were a little high but other then that my 2002 mmax would run 150 on the speedo best kind, I got my new belt today and installed it and now it only runs at 120, and the rpm's dropped big time from 8800 down to 8000 even, I then put my old belt back on and voila back to 150@8800 again, what's up guys? this is a new setup I done this year and I changed many items, is this too low of a helix angle? or wrong primary clutching??
touringguy03
- Jan 19, 2004
Are you sure you got the correct belt for your machine.
SRXdude
MM
If you put the 89L on, the RPMS will drop, as it is a softer belt. You have to adjust the weight in the primary to compensate.
I always had better luck with the 8DN.
MountainMax
Thanks, that is what I will do, getting one this weekend when I go out of town (no dealership here)......They have them in stock.
SRXdude
MM--Saw another post from you about clutching for racing.
I would stick with the 8DN belt if I were you. I would not put the 89L on. It is softer and will lower RPMs, but it wont last like the 8DN. 8DN should be the stock belt on this sled.
MountainMax
Actually I want to lower my RPM's on take off, im not worried about long life, I could just swap the 8dn belt on for normal driving, and race with the 89L
