happy10
- Jan 4, 2004
There is directions in the tech section for adjusting the power valves from the service manual. How do I adjust these without having the adjustment coupler tool to advance the servo motor. Can I apply a 12v battery to the servo motor another way? Thanks for any help....
T
taped
Guest
Start the sled, adjust idle below 1000 rpms and then power valves open. Then flip choke on full to kill sled. Adjust valves as per tech section.
ReaperSRX
wouldn't you just use the kill switch and leave key on instead of choking it off............Reaper
