Replacing heat exchanger 98 srx
98srx
Does anyone know the procedure for swaping a forward heat exchanger on a 98 SRX 700.
Not for sure on best way but pretty sure you have to pull the track! Drill out the rivets , disconnect the hoses etc... good luck
THANKS, TO ME IT ALMOST LOOKS LIKE I MIGHT HAVE TO PULL THE MOTOR, BUT MAYBE NOT,HOPFULLY i CAN GET A LITTLE BETTER HANDLE ON THIS BEFORE I START REMOVING STUFF I DON'T HAVE TOO.
Remove the track, tilt the motor foreward or remove, and start drilling out rivets. Have fun!!! ;):D
