heat exchanger question
98srx
Does anyone know the to change the forward heat exchanger on my 1998 SRX 700?
remove suspension, remove motor, remove steering column, drill out rivits, put a hydraulic spreader in the tunnel and split it a hair, should fall right out.
installation is reverse of removal
drastic oversimplification, but it probably gets across how big a job it is, not to be undertaken lightly.
