98-02 carb question
i dont believe that they are any different, although the fact that the 00-02's have the 3D ignition mapping makes me wonder a little bit. But I know the old ones still have the throttle position sensor, so i am almost positive they are the same (expect for the jets changed for a couple years) If i am wrong about this, someone else will chime in.
They are different. the 98-99 dont have a TPS sensor, just the switch for the TORS. You could run 00-02's on a 98-99 sled but not the other way around. The nozzels are also different but that could be changed out. ===SRXSRULE===
