oil consumption ????
BLUE LIGHTNING
London, Ontario
rode about 100km on saturday and burned about just over a 1/4 tank and burned about 250ml of oil or 9 Ounces of oil . runnin about 80km as an average speed. i'm using synthetic and was wondering should i be burnin more or less oil ( don't want to foul plugs or burn down a cyclinder) have it set at 23 mm on the oil pump cable 21 mm is the factory setting for semi sythentic and am running fully synthetic(amsoil). sythentic is suppose to be light and not a thick as semi-synthetic. i'm only 2 mm above the factory setting which is 21mm plus or minus 1mm.should i make the mixutre leaner or richer?
running a 1998 srx 700
