HyperMax
Had a great day at the weinie roast speed run in Cable WI. My '01 SRX had a best pass of 119.04 in 1000'
SRXSRULE
- May 2, 2003
Sometimes I miss the races ;( Still got the cooldown cart in the shed just incase. ===SRXSRULE===
tripple_tripple01
just wondering whta kind of speeds other sleds were running? f-7's......mach-z's?
yamaholic22
guessing that was the '01 with the 780?
I seen a few srx's run right around 100.My buddies f7 ran 111.98 which it is stock.All he does with the sled is speed run.There was a stock srx there that hit 112 also.
HyperMax
Yes, GEN II Simons CPR 780
cacsrx1
What is the difference between the Gen 1 and Gen 2 780?
nailsandrails
Those speeds seem a little high. A stock SRX does not run 112 in 1000FT without some work. Maybe you mean stock as in motor not touched? It would have to be dialed in good on clutching to get 112 out of it in 1000.
yamaholic22
clutching is considered stock by most people, and basically all organizations
HyperMax
GEN II uses a different CDI, more aggressive porting and bored carbs.
snowdust.in all form of isr racing rules,in stock class you can use a speed track,clutching gearing,lower the sled,etc.Yes it is stock reid racing speed run's all year lonfg every weeknd the are tuning and racing and they are running 112 stock.Theyt run cmsa which has some of the best tech guy's and they tear yoiu down to the crank.Not to sound like a jerk but pick up an isr rule book.
nailsandrails
I'm not mad at ya pro.
I mentioned in my post it would have to be a well clutched SRX to run those numbers. It sounds like it was exactly that. Good to hear it!!
