Anyone Try Those Launching Weights From Patricia Hauck???
Tyler, the Super Tip weights you can load up the heel of the weight by 14 grams, if that isn't enough belt grab nothing will be! Also I had another thought last night, not sure which belt you're using, but try a 8CH might help out the pro stocker as well.
Allen, I Did Try A 89l Belt And Sliped That Also, If You Load Up The Heel Of The Supertip Weights Don't That Bring Down The Engagement And Add Total Weight Of The Weight?? Pat's Weights Should Be Able To Change The Engagement Without Adding Weight To Heel.
Yes adding to the heel will affect the engagement and the shift rpm as well, but there's enough adjustability in them to work around it and find the right combination. We engage at 5700 rpm with them in our Improved Viper using a white heel clicker spring, 14.5 mm rollers and don't have a problem biting the belt with zero track spin (running a 13.5 x 136" track).
