Is there any clearance problems using a ripsaw track on a standard SRX skid?
thanks
thanks
It will clear with out studs as long as you remove the tunnel protectors & front heat exchanger protectors.
power valve
Yah I run a ripsaw with no problems just remove tunnel protectors like turk said
sxviper32
or drop and roll the chaincase, get longer drop brackets, and your good to go!!!
