coolant light flashing?
nystateboySRX
Ticonderoga, NY
Website
www.myspace.com
I put a new engine in my srx 600 today when I went to put coolant into it I did everything right. I bled the lines under the seat and infront. But the light still keeps on flashing. Any Ideas????-Garth :o|
Bleed...Bleed and yes, Bleed again!
This is inevitable...you have to bled it out at least a couple times (2-3 times). Get the engine warm (run at least five min.) then bleed the rear first, then the front. Rince and repeat..lol JK seriously...do this a couple of times make sure the top is loose on the coolant bottle. When I put my pipes on, I had to bleed 5 times before the light would turn off. Trust me this is your prob.
Confucious say: Man who walk through airport turnstile sideways...is going to Bang-kok.
Check your plugin on your sevor make sure it tight and 7 flashes is the sevor
probably a lose connection
