n2oiroc
here are pics of the 05 mountain skis for anyone interested. to run them you need 2 longer bolts 90105-10106, 2 new bushings 90387-10036, and 4 spacers 90387-16013. the stance is adjustable 1" narrower, stock width and 1" wider than stock. you can re-use your stock handles and carbides too.
specs
7" wide
40" long
1.25" deep keel.
specs
7" wide
40" long
1.25" deep keel.
What are they off of ? How do you change the width? Also they look very short. Are all mountain skis that short?
Thanks for all the info.
They are not short, it is the width that makes them look short. Measure your current skis and compare to 7" x 40" for the Mtn Skis. I have them on an '02 Viper 121 and I really like them.
There are 2 spacers on the through bolt that can be put both on one side or the other, or one on each side. I am still trying out the different ski stance widths to see how much difference it makes.
