Help with removing Kill Switch
ReaperSRX
New Liskeard, Ontario
I went and did it, just finished getting handguards on and i overtightned the throttle to the handle bar, heard a snap, i shattered the block where the screw goes in to secure block to bar, so took the throttle block apart, but i can't seem to get the kill switch appart to remove from block, does the top part(the part you push down on) just pull off,twist off or what, or is it part of the block(looks like it should come out)........now i have to find a new throttle block.........Reaper
You know, i thought it might under than label but i wanted to wait until i was sure, i ended up buying a new throttle assembly(comes with kill switch), they only sell it complete, cost $90 CND plus tax, oh well costly mistake, but i now know to never, never over tighten throttle assembly, lesson learned the hard way.........Reaper
