nystateboySRX
I have a friend that needs to know where and how many grease fitting are on his 2002 ski doo mxz trail 800 sled.   He would like to know if there is also a website.-Garth
greg
I don't know the number of fittings but there is a fitting behind the secondary clutch for the jack shaft bearing.
			03viperguy
might have better luck asking on www.dootalk.com   hope you find out
Junior
off the top of the head there's one on each trailing arm, one on the speedo bearing, and I believe there's 4 in the skid. (one at the centerpoint on each shaft)
I imagine there's more than that tho, that's just ones that jump into my head
Yes there is one behind the secondary on the speedo pickup, two under the pipe for the steering, and 6 on the rear skid.
