ATTAC or Tempaflow?
Blue4me
LaPine, Oregon
After reading such good reviews of the Holtzman Tempaflow at this site
I have decided my '01 MM700 needs one. After going to Holtzmans site
and checking specs I see the ATTAC does everything the Tempaflow does
and more, varies jetting for temp and altitude.
Where I ride the elevation is about the same but sometimes trailer to the
nearest peak about 3000 feet higher.
My question is does anybody have any experience with the ATTAC and
which one should I purchase?
The ATTAC unit will adjust automatically for elevation changes. It is quite a bit more expensive especially when you can buy Tempa Flows on the parts list frequently for $100 or less. The Tempa Flow can be adjusted manually for a few thousand feet elevation change once you get it set up at your normal elevation. If that is all the elevation change you will see, I would recommend the Tempa Flow. If you ride in spots where the elevation can change 2 or 3,000 feet in a day, you may want to buy the ATTAC. I'm a flat lander and have the Tempa-Flow. I love it and think it is one of the best after market purchases I have ever made.
