esishot
- May 17, 2004
I have an 01 srx and i am in the process of putting in a 136 inch M-10 and i have ohlin front shocks in my sled and i wan to get more clearance in the front so i can go in the back country easier. Any suggestions i am willing to trade shocks so i can have i higher one. When i put larger shocks in i wan tto keep my ski stance the same and have my steering stabilizers hooked up.IS MR. SLED ON A RIDE. I NEED YOUR INFO.
Mike
Mike
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
You could put on Ohlins shock extensions. Maxx Perf. has them.
yamaholic22
yes advant-edge has shock extensions and there is a guy on ebay that sells brackets that raise the front of yamaha's for rear long travels, to balance it.
bluewho
viper or sx shocks are the only way to go if you want alot of lift.
grapeape
Shock extensions should be enough. 97sx has no problems off trail, and it has the short front travel shocks
esishot
- May 17, 2004
ok
Bethviper has a pair of viper shcks for 200 should i get them or should i get extensions.which is better.
MIke
MIke
98srx6
Get the extensions if you like your ohlins.
shortstop20
- Mar 6, 2005
yamaholic22 said:yes advant-edge has shock extensions and there is a guy on ebay that sells brackets that raise the front of yamaha's for rear long travels, to balance it.
I seen those the other day too, what do you guys think about those brackets??? Do you think they sound like a good idea if you want more clearance or just a gimmick??
aSRX600guy
you can always crank the preload
Junior
I believe that the SX-R spindles are higher, you might be able to switch spindles, I never tried interchanging them tho, don't know if it'll work, anybody else have info?
that might be the easiest way, raise ride height without interfering with alignment angles any.
yamaholic22
eric and i were talking about those brackets on ebay for the long travel in the srx. We thought they definately looked like something to consider. Only like 20 bucks too.
shortstop20
- Mar 6, 2005
If they work good they're a steal at $20.
I don't believe any other parts are needed besides the brackets....correct????
After installing you would just need to make some alignment and camber adjustments maybe.
esishot
- May 17, 2004
k
i hopefully am trading a guy my front suspension for his which is a BLT suspension from fast 10 iches of clearance 44 inches ski stance and works front shocks.hAve you heard anything about it.
Mike
Mike
98srx6
You should keep your ohlins and get those brackets off of e-bay. For $20 you cannot go wrong in trying them.
