Lighting Roller ???
Simply Insane
Harrison Twp. MI
Does anyone out there have any experience with these clutches???
How are they? are the easy to work with? thinking of getting one
for my 2001 SRX . Thanks for any info it will be greatly appreciated.
I never bought one (I got the bender roller rooster) because since it uses stock helix's, this would actually cause problems with angles, because everyone else says whey using a roller helix you can/should go down about 4-6 numbers because they are so efficient, woulndn't this cause trouble if you were still using the stock angles, with this extra performance...
You can buy "stock" helixes from Dalton and other manufacturers in different angles including multi-angles. The fact that the Lightning Roller uses stock type helixes doesn't limit its use. It is true that the better efficiency calls for a reduction in angle of 4 to 6 degrees over the stock button set up.
