startor removal
sxviper32
Valparaiso, Indiana
i know this belongs in the classifieds but its not gettin any hits down there so i just wanted to post it once up here, looking for what i believe is called a flywheel remover so that i can take the stator off the crank to get the case apart on my 2001 srx. anyone have one let me know, thanks!!!
sxviper32
Try a three jaw automotive puller. I have used one before and it works. You will need a 5" or a 6" one to do the job.
You can also use a three bolt harmonic balancer puller as well, but you will have to remove the starter pawl bracket from the flywheel first and then insert three longer bolts through the puller and into the threaded holes of the flywheel.
