sxviper32
will a viper crankshaft fit in a 2001 srx 700? thanks!!!
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
It would probably fit, but I think where the rods connect to the crank is different. I'm not positive though, so don't quote me...lol
Junior
hope I don't get in trouble for screwing up this one to, but from what I know they are interchangable, but not the same part, viper uses porkchop style crank throws vs the SRX's round style. means less crankcase compression, and less rotating mass in the crank. part of why the vipers feel lighter.
yamaholic22
yea i bit my tongue too, i'm pretty sure they are interchangeable, but didn't want to say anything because i'm not 100% postive.
Junior
well I've done it, but I'm not sure if it was an 01 or 02 case.
sxviper32
junior, was there a significant difference in weight or performance when you went with the viper crank? thanks guys, much appreciated!!!
Junior
no difference in et or mph
I doubt a trailrider would even notice the difference at all
yamaholic22
does anyone know the actual difference in weight between the two?
Junior
it's a couple pounds, alot for rotating mass, but I think that the loss in crankcase compression ratio negates anything you pick up in rotating mass.
it should be in the advertising info for the vipers back in 02. I don't have 02 stuff kicking around tho. somebody will have it tho I'm sure.
yamaholic22
wow a couple pounds would make a big difference if that was the only change, would be able to rev a lot quicker.
I belive its approx. 2.6 LBS. A local racer dynoed a 01 srx using a Viper bottom end (cases and crank) and found about 5-6 HP increase.
yamaholic22
that would be interesting to do if you had both lying around. Just take all the best from each, build one awesome sled with all "stock" parts.
Junior
yamaholic22 said:wow a couple pounds would make a big difference if that was the only change, would be able to rev a lot quicker.
that's what we predicted and why we tried it. didn't work out how we had planned tho, for whatever reason, she didn't go faster.
