viperino
looks like my coolant system stops pumping coolant around once i start running...i pulled the water pump cover off and the impeller is fine...even turns when i pull recoil to turn crank....made sure this was not an airlock either...i'm pretty sure it is a problem with the impeller shaft gear on the crank....has anyone out there run into this problem?
snow melting fast...
pr
pr
