Kimzrcc
Just finished welding all parts for the lift from the Tech section.
Purchased trailer jack that is 15 inches lift rather than 12 in as stated in parts list. Better to have some extra play!
When I put it thru a trial run, the jack will not lift the legs to the 90 degree (straight upright postion).
I double checked all measurements before welding and after.
Did anyone else have this happen?
Any suggestions?
Kim
Any suggestions?
Kim
Kimzrcc
ttt
Someone else must have tried this lift!
I built one of the lifts from the plans here and it doesn't get to 90 degrees either. Just meassured it, 84 degrees.
http://www.totallyamaha.com/forums/showthread.php?t=8793&highlight=sled+lift
