1999 SRX700 with bad rod bearing, should I buy it
jbperkins
There is a 1999 SRX700 with a bad rod bearing for $1000. Replacing the bearing would not be a big deal for me to do myself. I have a pretty well equiped garage. The sled is in otherwise good shape and has a long travel rear suspension upgrade. Good deal or forget it?
grind the welds off, lol
even without a welded crank it's a mofo tho, I'd rather send it out than do it myself.
you could also part the sled out.
I would have to carefully grind the welds down and reweld it after I put he crank back together is my assumption. Am I totally wrong in assuming that replacing the rod bearings is possible? Is it a spot weld or bead all the way around?
99SRX Bad Crank Bearing
Buy it, I know that sled!!!!!!! If I were going to be riding next year I would Rebuild in a heart beat!!!!!!
yea i would buy it, i think its worth it. Even if the crank was junk, you could get a different crank easy. Rod bearing hey? Sounds like someone didn't summerize it right.
Summer!
Yamaholic, Sled had 9651 miles on her and was still @115 on speedo when she went! You got to love thoses SRX's!!!!!!! Come and get it !
99srx w/ bad rod bearing
GET IT!!!!!!!!!!!!!!
THE long travel makes that sled complete :WayCool: :WayCool: :WayCool:
I just ordered an ATTACK, but i will never get rid of my SRX ;)!
ya that's accurate, grind down and reweld once she's together.
it's just a spot weld, walk in the park man.
the pressing is still a major PITA tho, I'd recommend sending it out. and I do almost everything myself.
